Replacing Impeller
maphillips3
Does anyone know about how much it should cost to replace the impeller on a 1986 Bayliner with a 2.3L Volvo engine and a 275 Penta outdrive? I am new to the whole boat maintenance thing. Thanks!
paboater
Re: Replacing Impeller
Are you going to do it yourself or take it to the shop to get it done?
maphillips3
Depends on how difficult it is to fix. Is it something a person with a general amount of mechanical ability can do, or should it be taken to a shop? What are the chances I am going to screw something important up when trying to change it? If it is not too expensive I would probly take it to a marine shop. Do you know how much it would run at a Marine shop, and how much the impeller would be by itself? Thanks for helping!
MH9371B
Probably 2 hours labor. So, depending on the labor rate at your shop, you're looking at that, plus approx. $15 for an impellor, and they will also probably charge you for changing the gear lube out for your outdrive. I'd say around a $175-$200 job at a mechanic.
MH9371B
Oh.. and chances of screwing something important up when trying to change it? Very high, if you are new to boat maintenance. I can change out a starter, alternator, raw water pump, power steering pump, but I would never think about disassmebling my lower unit.
paboater
I would buy a Solec manual for your motor, read up on how to change it and decide it you think your capable.
maphillips3
Thanks for the feedback guys. Greatly appreciated. I will probably take it and have it done at a marine shop.
