What type Alpha one do I need???
Starr MUrray
I just bought a speed boat with a 1987ish Mercruiser 260 V8 engine. Engine runs good but only one problem, no outdrive. What outdrive do I need to mount on the V8? What gear ratio? Thanks.
Don S
Re: What type Alpha one do I need???
Alpha I (NOT an Alpha I Gen II)<br />1.50:1 gear ratio
Starr MUrray
How do you determine that it's a 1.50:1 gear ratio by looking at the drive. This guy I know has one but doesn't know how to determine the gear ratio.
Haut Medoc
The only sure way is to count the teeth. Take the top off it should be 22/20 I believe.......
Starr MUrray
I've heard about the 22/20 teeth thing. What "top" part do I remove to count the teeth? Do I separate the lower unit from the mid unit?
Haut Medoc
The part with 4 bolts on it on the top, no you do not need to separate the upper and lower cases.
