Bigdave196
Thread starter- Joined
- Apr 13, 2009
- 120
Currently installed in my 1997 Blue Water Monte Carlo is the following 5.7L 250hp TBI Non-Vortec Volvo motor, SX Drive.
5.7GLI PLKDCE
4110145128
3868732
ECU - 57TBI/97L001 Then something on the side of the TBI reads BCTU 16184069.
Drive unit- SX-C1 1.51 - running a 19* 4 blade Solas Aluminum prop.
4112031506
3868393
I want to do a Vortec re-power and possibly stroke the motor to a 383, and still maintain the TBI. I can replace the TBI with a carb if necessary, but if I do will the Distributor and ignition system work? I understand that I will have to re-flash the ECM for the TBI if I build a stroker motor, but either way I go I will need a new block. Here is why....
Issues are as follows, when I bought the boat 5 years ago, I was unaware of the "Quick-steel/jb welded" repairs done to the external part of the short block on both sides of the block. I took the advise of, "It's not leaking, don't worry about it", and it has yet to fail. The cracks were external and not internal from the previous owner not properly winterizing the block at one point. When the head gasket failed this summer I started plan a re-power because of the hours on this motor which has almost 1100hrs and this boat spends its days pulling tubes, Sea-Sleds, and wake boarding and all the full throttle abuse that comes from it.
With the heads rebuilt and re-installed the motor achieved 4800-5300rpm easily with a 19* 4 blade Solas propellar, before I noticed that there was the water leak from the same side that the head gasket failed. Thats when I noticed that there was a slight water leak between the #3&5 cyl where the head gasket failed. The machine shop says that there is a very good chance that the block has a small crack and that it's very common for that to happen on marine engines. I was the one who tore down the motor and
This is where I need advise/help.
Do I find a new Short block and attempt a 300hp repower and use the same heads that were rebuilt?
Do I re-power with a new block and Vortec heads and find a different intake manifold to use the same TBI, and possibly re-flash the system?
Do I re-power with a Vortec motor, ditch the TBI and use a 600-650 cfm marine carb to achieve 300-350hp? If so, will the ignition/distributor work with out the TBI?
Do I build a 383 stroker, ditch the TBI or Keep the TBI?
ANY and all options and ideas are welcome. Experience goes to the top of the list. Thank you in advance.
Dave.
5.7GLI PLKDCE
4110145128
3868732
4112031506
3868393
Dave.
