MSmith3615
Thread starter- Joined
- Jun 24, 2005
- 209
I need all the help I can, I recently had my boat in for service for a tune up and to check the cooling system. The boat was overheating alittle, I dropped it off a few days went by and they called me and said everything was ok. When I went to pick the boat up I was told is was not Idleing right, when I heard that I was suprised because when I took it in it was running great minus alittle overheating. So me and a tech went to the river and tried to run it, It would not start. We took it back to the shop and after some trouble shooting we determined it was just flooded. So once we got it running something just did not seem right, it just did not sound right, sounded like it was running on 6 cylinders instead of 8. They pulled the plugs and water just came dripping off them, otherwise water was in the engine. Wow I was shocked the boat only had 300 hours on it and I know that water had never gotten in the engine before, I checked the plugs before the tune-up, they never have gotten wet. So I was freaked out, I asked them what all they did and they said a tune-up and replaced the impeller. So I wonder what caused this? They told me that they are not responsible but I know for sure that before I had it serviced water was not getting in the motor, I'm a certifed mercruiser tech and have been to school and everything which does not mean much but I know water wasn't getting in the engine. I checked the boat out 100% before took it in. I almost sure it has somthing to do with the new impeller. All I know is they messed with the cooling system and now water is getting into the block and I mean alot of water. Checked compression and it was 170-180 and all cylinders. What could cause this?Please help, any suggestions to what might of happened please advise. 1985 260/mercrusier/5.7/v-8/300hrs.
