Manipulator
- Joined
- Apr 11, 2005
- 743
Well after driving 3 ½ hours to my boat, taking off the top, icing down the beer and lathering up the sunscreen the damn thing is a loss for power. First let me tell you what I have, what I have done, and then the symptoms. Its a 1983 Sea Ray SR2250 cuddy. It has a 5.7 GM mated to an OMC. Here is a little history. The boat has 750 of papered hours on it. The lower unit was rebuilt about 200 hours ago. I have had the boat two seasons and have changed the oil and lower and upper unit gear lube regularly. This spring I rebuilt the carburetor (4 barrel Q-Jet), I replaced the points, condenser, rotor and cap. I replaced the spark plugs, I replaced the lower and upper fuel filters and cleaned the flame arrest. I set the dwell and timing. First weekend in the lake Dad takes her off the trailer and the thing has no power just like now. He comes back and we take a look and I have two spark plug wires flipped. We flip them and go for a spin and it runs great and has plenty of power. We run all weekend with no problems and she runs great. I come down the following weekend and it again runs great all weekend without any problems. <br /><br />I come down this weekend and it has a loss for power. I could keep it on a plane at 2800 rpm and now it takes 3400 to maintain a slow plane. I punch it wide open and it wont get my speedo over 20 mph. WOT I could do 35 mph on the speedo last time (probably 5 mph off as I know she will do 40 mph at WOT). I can get the engine rpm up to 4000 rpm but there is no gusto to go with it. Before I could get it to 4200 rpm and it had plenty of punch. The guy that had the boat before got a prop designed more for economy than performance. I believe the rpm range is 4200-4800 for this engine. Anyway, it ran great a few weekends ago. Here is what I have done so far. I checked the lower unit for any prop damage. It did have some lake crud growing on it so I cleaned it all off. There is no visible damage to the prop or lower unit. Besides I dont remember hitting anything to caused damage. I checked both fuel filters and they are both fine and there is no water in the system. I checked the carb and its getting plenty of fuel, I checked the distributor and rechecked the points, they are like new and I checked the gap and its fine. I went and bought all new spark plug wires and installed them. Went for a test drive and its doing the same thing (lack of power). I checked the timing and its right on. I checked to make sure the distributor is advancing and it is. I have checked out the fuel system except the fuel pressure but the carb seems to be getting plenty of fuel and the engine does not act like it is starved for fuel. I checked the ignition and it all checks out. I am at a loss to how this thing can go from running great one weekend to a major lack of power the next. It revs up great without any problems. Even under load it seems to run fine but there just is no power. It idles flawlessly and starts right off with no problems. Any thoughts? What about the coil, could it be bad? What about the lower unit, is there a clutch or something that may be slipping? What am I missing here? Well I couldnt fix it so we came home. What a bummer! Oh yeah, there seems to be some vibration in the boat at 1800-2500 rpm.
