g0nef1sshn
Thread starter- Joined
- Feb 24, 2015
- 1,291
Nice to see someone else with butterflies about first time out. I am not sure I trust my work on the fuel system. I am not up on this at all, but I think the neutral safety switch is a function of the control, not the motor, so if you are in neutral at the helm it should be fine. Does it need a neutral signal from the motor?
Ron
The motor was originally a control/console motor ( by original i mean the previous owner). It had a home made bracket for the steering arm. I got it with out the control, but have the wire harness. There is a bracket inside the cowling where tiller motors had the switch mounted. Which i believe this motor was originally a tiller by its serial number. The switch itself is not expensive, just havnt ordered one having only recenty finding out where it should be mounted.
