4.3 Temperature switch or sensor?
jpg
How do you know if you have a temperature switch or sensor? Also, where is the location of each? This is a 1990 Rinker 4.3 Mercruiser
Re: 4.3 Temperature switch or sensor?
A temp switch is an on/off device and would be used to turn a TEMP light on or off. If you have an analog temp gauge, a sensor is used.
Don S
You probably have both, what kind of problem are you having?
jpg
had a valve job done and when i got the boat back the temperature gauge didnt work. I replaced the sender and found a wire that was left off. But now It dosent seem to get any warmer than 120 degrees, It use to be up around 160 to 180.
Don S
Are you sure you installed the right sender for your gauge?<br />If you found a wire off, did you try it with your old sender? What color was the wire you found?<br />Is there a thermostat installed?
