bmowers
Thread starter- Joined
- Nov 19, 2012
- 65
Bayliner 175BR 2008 Mercruiser 3.0, 135HP Alpha 1, Gen II drive. Runs 55 hours per year
I just did an impeller service on the lower unit using the Mercury drive kit. I also pulled the upper drive and checked the alignment, Bellows and Gimbal. I replaced the bell housing seal with the kit and all seals except main bell housing seal that looked perfect.
I put everything back together, observing the shifting level forward etc. All went well. and today I hooked up the garden hose at 3/4 volume on muffs and fired up the boat after a 6 month sleep. Started right up after 10 pumps of the throttle. engine temperature was pegged at 100 as usual and started to climb up to 175 at the top of the gauge. I hopped down to look at the water spitting out the the engine and noticed that the transom exhaust ports were NOT spitting out any water as they have always done the past two years I have owned the boat. Hot air was coming out and maybe a little steam. All the water seems to be coming out of the prop. I pulled the small quick release hose from the main water pipe that exits after the thermostat and no water going through it. Temp moved a needle past 175 and I shut it down. Now everything worked perfectly when I ended the season last October. Also, I pulled the blue water drains to see if the engine was getting water and yes, there was plenty of very warm water pouring out after shut down.
Questions :
1.) Is is possible that the impeller is not spinning freely? Can the cover be put on too tight? I snugged it down good but not overly tight.
2.) Could it be the thermostat not opening?
What else can I check. I don't think that water is circulating through the top of the engine now;.
Brian
Questions :
Brian
