earnies2
- Joined
- Jul 16, 2005
- 22
I removed outdrive becaus of u/joint - gimbal bering noise gimbal bearing came out with out drive does that mean the housing that holds the bering is no good it is not corroded the bering was stuck to the shaft the shaft looks ok .the seal behind the bering its spring came out ,i am having a hard time removing the seal any ideas would help. The u/joints look and feel ok but i am going to replace them any way! should i remove the drive shaft from the outdrive to replace the <br />u joints? if so how and do i need any special tools
<br />THANKS
