Hi...
<br /><br />I have a 1987 3.0 mercruiser that just started to overheat. Temp used to be around 170. Now 200+. I read some post and thought that my impeller was gone. Plus rubber pieces in the intake on the outdrive good indicator. I dropped the lower unit. It's a alpha one. I replaced the impeller and it needed it. The old one was done. Put everything back together. Starts great, temp right back up to 200+. This is fresh water cooled. Before the impeller install, I check the t-stat hoses and water pump on the engine and all seemed fine. I forgot to say this is on the muffs on garden hose.<br />All the hoses seem fine. The problem is that I'm not getting water to the exhaust manifold or to the water pump on the engine. So I turn the hose on with engine off and pull the intake hose off to the T-stat. Hardly any water, only a trickle. Even with the engine running same deal. <br />I have the same problem now the new impeller is in. I thought it was the impeller! I also replaced the t-stat while i was there.Now what<br />??????<br />I'd rather diagnose rather than be a parts replacer.<br />Risers? <br />Bellows? <br />no clue.
