Seaweed / Overheating
Mnemonic
I went out to fire island yesterday, and as im backing into the slip, i guess i sucked up some seaweed, and the temp went right up to about 205... i shut her down and drifted into the slip...<br /><br />I dont want to damage my motor, but I really dont like being embarrased like that in a public slip... is there any way to prevent sucking up seaweed?
KaGee
Re: Seaweed / Overheating
Try heading in instead of backing in. <br /><br />I thought I saw a post in the "Boat non-motor" section about weed control earlier in the spring. You may want to do a search.
Mnemonic
My boat is very hard to get to the bow without going thru the cuddy, climbing up, etc... <br /><br />When i have 6-7 people on the boat, backing in is the easiest way.
Shifting to the opposite direction of travel will usually clear the water intake........It only takes a second or 2.....<br /><br />Fwd to Rev,.. or vice versa......... ;)
vonway
i have had this problem and now the engine is running really rough.. (the launch was full of seaweed) about 2 minutes from the launch at idle (nowake)speed the temp shot up to 220 and i turned around to head to my slip.. within a minute the temp started to go down slowly and then just started to run rough and ready to stall .. got in slip and restarted , runs bad. ANY ADVICE
vonway
today I went to marina to try and start boat, with no luck , i pulled the plugs and found they were wet with gas, checked oil, full and clean. replaced fuel filter and spark plugs, still wont start, What is the deal???? THANKS
Mnemonic
why are you jacking this thread? You posted this several places and should just wait for an answer in your own thread!
