4.3l intake manifold
SMF
Can you use a after market 4 bbl intake like a aluminum holley to up grade a 2 bbl intake? It's for a 1986 4.3l with 12 bolts.
Northern Eclipse
Re: 4.3l intake manifold
You can use a aftermarket intake just be sure to use good gaskets... If you boat in the salt I would think corrosion might be a problem..
bluewater19
You want to use the edelbrock performer intake for this motor they make a direct marine replacement and it will wake that motor up!!<br />I did the same thing in my bluewater.<br />You will only like this if the Idea of 10-20 hp,<br />A few mph on top speed and better part throttle fuel economy sounds like something you want. <br />Good luck!
Don S
And make sure it's a Marine carb, not an automotive.
SMF
Thanks Guy's sounds like a good project.
jdtower23
Is this Edelbrock marine performer you're talking about aluminum?
John
fourwinnsdook
Keep us posted on this, i have an 86 four winns i'de like to do the same thing to. Part #'s would be great!
