Oil Pan sprung a leak, is an Automotive replacement acceptable?
The Oil pan on my '88 4.3LX sprung a leak. Can I use a standard automotive oil pan as a replacement? The dipstick is on the starboard side, does this make a difference?<br /><br />I plan to change the timing cover at the same time. Can I use the automotive version? Are "marine" gaskets necessary?
tommays
Re: Oil Pan sprung a leak, is an Automotive replacement acceptable?
i think the biggest difference is the dipstick is set up to pump the oil out on marine pans<br /><br />i dont think theres any difference in gaskets that dont contact water dirrectly like the head gaskets<br /><br /><br />tommays
KaGee
The pan gaskets and the timing cover gaskets are all the same... no such thing as "marine". The pan will have to be compared to make sure the drain hole is where it should be for your application.
Scaaty
And on the replacement pan (and I am simply excited that someone here has the foresight to also replace the timing cover!!!!)...make sure you toss a good coat of the best paint to protect it from rusting out again too soon.
Scaaty
(Whoops, double post)
Wellcraft260
I used the chrome plated one on mine ,only 35 bucks. Not sure if this causes cathodic protection issues for you saltys though.
f_inscreenname
You can always have it powder coated.
