Re: Inboard transmission kicks fluid out
How long did water stay in the trans?.. eeek.
Hope you caught that soon.. The clutch plates don't like getting wet..<br /><br />Are you sure you got all the watery tranny fluid out?... Did you drain the tranny cooler too?... <br /><br />If the fluid is even slightly milkey, change it again..<br /><br />What fluid did you use?.. ATF(automatic trans fluid), Dextron 3?..<br /><br />When you "top it off" are you topping it off to the mark on the dipstick, or just filling the trans to the top of the filler hole?... <br /><br />Overfilling it will certainly cause a leak (blow out seals, blow oil out the vent), and overfilling may cause slipping.. <br /><br />I'd clean up the trans and the bilge as best you can, make sure the fluid is not milkey and that it's filled to the mark after the trans is at operating temp, then run it to try and pin-point the leak.. <br /><br />Watch the vent on the top of the trans next to the shift lever for leaking..<br /><br />Hoping for the best for ya..<br />Keep us updated..
