- Joined
- Sep 22, 2003
- 28,772
Re: I opened valve cover
You can check for a bad cam by removing the intake manifold, loosen the rocker arm nut on the suspected valve(s), remove the push rod, and then extract the lifter(s). Check the bottom of the lifter, if the cam is bad, the bottom of the lifter generally shows a severely worn and concave surface as well. You can then peer down the lifter bore to see the cam lobe. If the valve was not moving very much, the wear will be obvious.
