I recently purchased a 1998 Bayliner Capri 1850SE. Has a 4.3 Mercruiser Alpha One. Runs great. Have noticed that the Gear oil resevoir drops from the FULL line to the ADD line in about 15 hours of use (mostly tubing and skiing). I called to get an appointment but everyone is about 3 to 4 weeks out (crazy). Can I continue to operate if I monitor the resevoir level until I can get into the shop? Will any damage be done. I have not seen a slick on the water anywhere, I cannot see and leaks on the outdrive, there are no leaks in the engine compartment (bilge is dry too). Any ideas what it could be? Thanks.
