filmmaker101
- Joined
- Jul 30, 2005
- 24
I recently repowered my 89 Maxum i/o, 3.0l Mercruiser motor. After getting the motor in, which is 91, I found that this motor has electronic ignition, and there are 2 wires that are not needed for the boat connection on the left insert of the distributor. The motor<br />started up, but seems to idle very poorly. It runs pretty well at higher rpm. I replaced the plugs, cleaned the distributor contacts,<br />wire brushed some of the other contacts, checked distributor wire connection, It has new gas with clean carb.<br /><br />I also have click click click ont he starter when i turn the key. that never happened before so i removed and tested the starter and all is fine there. i did notice that there is a purple/white wire missing, (according to the wiring diagram), from the starter. (the wire that the diagram shows going from the starter to the coil). i dont have an old fashioned coil in this motor, its electronic igition and electronic coil.<br /><br />I also verified that timing is correct.<br /><br />Any clue what could be keeping this motor from running better at idle speed?<br /><br />any and all help would certainly be most appreciated.<br /><br />thank you,<br /><br />dice
