Just bought this 1984 Kayot Deckboat with a GM 5.7L and Rochester four barrel. Took it to the river for the first time cranked after a few tries. Rode around at idle and higher RPM for about three hours then when going back to idle or neutral it would not stay cranked. I had to pump the throttle several times and then it would die each time I put it back in gear. After fighting with it for a while I was finally able to get it in gear and go. I then found that I had to move the throttle back and forth slightly to get it in higher RPMs once ther it ran fine. <br /><br />My neutral RPM is around 600-700. My RPMs don't seem to be fluctuating. Temp. runs below 160. Oil pressure between 20 and 40 PSI.<br /><br />I'm not sure if I'm running to lean or to rich.
