FreeBeeTony
- Joined
- May 15, 2002
- 3,997
I have been thinking of performing this test for sometime and finally did it.<br /><br />Using a jumper with aligator clips on either end I shorted out each plug wire (with a probe on one end of the jumper wire) at the dist cap. I did this test at different throttle positions while under way. And to my surprise when the "bog" occurred one of the cylinders (#3) was not firing. It was defintly firing at a lower RPM. I did this test a few times to make sure!<br /><br />By the time I got back to the dock it was getting dark and the manifold was too hot to take out the plug.<br /><br />This is the first conclusive test I have run thus far!!<br /><br />Now the questions are:<br /> <br />1) Why is this cylinder not firing at higher RPM's? Guess I need to determine if it is getting spark. Why wouldn't it not get spark at higher RPM's and get spark at lower RPM'? The wires and plugs are new! Could I pull the wire of this plug and put it on a "test plug", bring the boat up to speed and check for spark?<br /><br />2) If it is getting spark, could this be an indication of a worn cam or possibly even sticky lifters? I would then pull the valve cover and measure the lift of the cam. Or is there something else I could/should do? <br /><br />If the cam was worn this bad causing the cylinder not to fire, would I see evidence of this in the vaccum test?.........<br /><br />I know I need to run more test but I am very excited because I feel I am finally on to something!<br /><br />Am I causing any damage running the boat like this?<br /><br />Any other suggestions with this new information?
