Re: 1991 OMC Cobra---keeps running (sputtering) roughly after shutoff
the engine can kick a bit and sometimes it causes a slight rotation of the crank in the wrong direction. This causes a suction on the exhaust side sucking water into the engine through the ezhaust which is in the water. Once water is sucked in and he valve closes, the water is a liquid and liquids can not be compressed. The piston comes up the cylinded and tries to compress the water but it cant locking the piston from coming up any further and locking the engine. This is a prticularly bad condition and can lead to a permanently seized engine if not relieved/remedied fairly quickly. It can aslo lead to ruined fly wheels and starters, some times even starters have broken off their mounting creating expensive repairs. As Tommays says, fix the problem to avoid getting in this condition. <br /><br />A well tuned and properly set up engine shouldn't do this.
