gm280
- Joined
- Jun 26, 2011
- 14,605
Art, When you build your cradle, make sure it is moveable and with side supports. This is my base for my cradle without the side supports attached yet. Yes, my boat is a tri-hull design. But it really doesn't have to be anything special. And the lower you can make the cradle, the easier it will be crawling in and out of it as you proceed on the work. I also use screws and bolts/nuts exclusively so that when it comes time to take it apart, I can use the lumber for other projects as well. I hate to throw things away. Second use is a good thing in my thinking. JMHO!
