"Smokey" 351efi 1993, anybody??
finneri
Have a 1993 351 5,8l efi w/omc cobra. When idle, it tend to smoke, mostly white smoke with maybe 20% black smoke. This only happens at idle. Idles little bit erraticly, 600-800 rpm!!!!! Runs fine in the rest of the rpm range. Compression is good, changed fuel injectors and a fuel distributor. Anybody have any ideas regarding the smoke and the erratic(variable) idle????<br />Finn
imported_scott_m
Re: "Smokey" 351efi 1993, anybody??
Not sure on the ford motors, but two areas to check could be the throttle position sensor (TPS) and Idle Air Control motor (IAC). A failure of either of these (both on the throttle body) can cause the symptoms you are experiencing.
finneri
Thanks MackSea, I'll look at that. Anybody else???
l1lmonsta23
I'd bet money it's the IAC as well, Ford's are notorious for bad IAC's. Other than that, I'm a chevy man.
Purebreed
The tps would probably make the boat run erratic.. I would also look at the IAC.
finneri
Thanks guys, would a computer see what the problem is?? There is a hookup on this 351.
What temp is your motor running at? you can get a normal Ford EECIV code scanner to hook up to the EFI system to see if it has a code in the system.
finneri
The temp is stabel at 160. Thanks for the tip.<br />Finn
finneri
I changed the IAC and the TPS, still doing the "smokin". Only at low rpm. The motor runs great exept for this problem. Any other sugg.????
finneri
searay3
Injector resistance? Vacuum leak? Electronics are generally pointing to a mechanical failure. Since you say the compression is good, I would look at fuel delivery.....my 2 cents
rbezdon
did you get the code scanner and look for codes?? The boat itself may have your answer and it know better than all of us guessing based on limited info.
finneri
I finally found a mechanic that has a scanner that works on this 351, this time of the year they are way to busy.Thanks for the respond though!!!!!
