Was running great all season then started to hesitate once you thottled it. Had to baby it up but once I got up the RPMs it continued to run smooth, but when I brought it back down to idle and then back up it would hesitate then sometimes stall. <br /><br />Got worst within hours to now it won't even start.<br /><br />Changed cap and roter and now I have to replace the starter because it failed from too much cranking I guess (all it does now is spin but won't actuate to flywheel).<br /><br />Check choke, seems to work fine, replace water separation filter and carb filter, tried timing buit still the same problem of not starting and when it finally did, stalling when throttling up. Also checked carb and it seems to be getting a steady flow of fuel.<br /><br />Any suggestions would be greatly appreciated because the starter is going to cost me $180 and I don't want to burn it up searching in the wrong places.<br /><br />Thanks in Advance and Sincerely,<br /><br />Allen afmnet@midwaynet.net
