Outdrive Question
jg440
Hello All, first post here.<br /><br />I have a 72 Schuster (tahiti) boat, with I believe the original Mercruiser engine 3.0 140hp and outdrive. I am trying to figure out the model and year of the outdrive (Pre Alpha, Alpha1 etc.) I have the below info<br /><br />Mercruiser<br />H.P 120/140<br />SN/3357372<br /><br />Additionally I have noticed the outdrive oil is milky. I know this can be bad but I believe it is due to the vent screw not haveing an o-ring seal on it??????. I saw oil (just a little) comming out of it while I was running it on land (with a hose of course) I would like to change this ASAP. What type of oil is needed for this model outdrive? Additionally I have 1 drain and 1 vent screw, I should fill from the bottom, right?<br /><br />Also should I use a certian o-ring type seal on the screws or will any type that fits work.<br /><br /><br />Thanks
jg440
Re: Outdrive Question
Ralph<br /><br />Thanks for the quick response. That site is a wealth of info. I do indeed have a Pre-Alpha I actually have two as the boat came with a spare engine and out-drive<br /><br />I did not find what type of oil to use, it mentioned Quick Silver but no viscosity<br /><br />would it be 80-90W? Can I use synthetic?<br /><br />Thanks
Alumarine
For the drive unit use Quicksilver Gear Lube Premium Blend (High Performance) it's blue/green in colour. For the price I hope it's synthetic.<br /><br />Yes, fill from the bottom until it comes out the vent. Best to use a pump that is sold at boat stores.<br /><br />The plug seals are very inexpensive at the dealer but I suppose an o-ring would be better than nothing.<br /><br />I wish I had a spare drive and engine. Hang onto them.
Ralph 123
The washer may actually be there. They tend to stick in the screw hole cavity. You can get new screw kits here on iBoats or anywhere for like $5<br /><br />WHAT EVER YOU DO, DO NOT PUT A MAGNETIC TIPPED SCREW in the fill hole (lower unit). Pre-Alphas do not have the Clarence for them and the tips will be sheared off (learned that the hard way).<br /><br />The Merc premium gear lube is good as is Sierras premium gear lube. Penzoil also makes a premium synthetic gear lube. They all say for Merc I/Os, etc. You can pick it up at any marina, iBoats, etc.<br />
<br /><br />
<br /><br />
crazy charlie
Ralph,is that what the outcome of your magnetic plugs were??? I didnt get to read the rest of your post a few months ago after they came apart..Charlie
Ralph 123
Yes. They had to be completely broken down, inspected and flushed and resealed. I just got them back and finished repainting them. Just in time for $3.50 gas. I am starting to wonder if I am even going to see the water again this season...<br /><br />Sierra has issued an urgent alert to their dealers telling them not to use them on Pre-Alphas and they are changing all of their literature.<br /><br /><br />
lowshovel1
Ralph, Whats the chanse of them compensateing you for your time and money?
Ralph 123
Sierra paid for the labor and supplied the parts. They really stand behind their products. I of coarse, ate the lost time and my labor. All this for $5 screws!
jg440
Ralph<br /><br /><br />Thanks for the update!!<br /><br />Jay
