1984 flotebote the heratige 28ft pontoon/ "3.0 omc?? evinrude, im lost
shidlerju
so completely lost, had a 89 bay liner, i figured it out couple years ago, but this has me stumped
1984 harris flotebote the heritage 28 foot pontoon with what i believe is a 3.0 OMC motor (GM)?? and an Evinrude stern-drive
stern drive has the number 380996 on it not sure what it means but its also in the pics
also the mototr has a hole towards the rear, inspection plate, acc. hole, ??? in pics as well
also from what ive read i also have a clutch pack?? for my trim but it wont go up or down, opened it up and it was "MUD" inside
included pics is what has me concerned, looking for parts, any help is appreciated, as always thanks in advanced, during and after....
well ive sat here trying to upload pics but apperantly its not gonna happen tonight...
any help here would be appreciated
GA_Boater
Welcome aboard.
You need to have at least 3 posts to upload pics. 2 to go.
GA_Boater
That's 3, give it a shot.
Click on the Forum Help link the sig below for photo posting help if you have trouble.
southkogs
Welcome aboard:
'84 OMC should be a mechanical shift Stringer ... but depending on what the "hole" is you're talking about (especially if it's on the back of the stern drive just under the top cap) you may have an older Stringer on there.
Clutch pack isn't for your trim, it's for your tilt. Trim on a Stringer (if you have it) will be on the front of the engine. If your tilt isn't working, I'd start by checking power to the solenoids and the tilt motor and then go from there.
On the engine itself somewhere (mine is on the starboard side rear motor mount) there will be a tag that should read something like: 302SPHRCRA, that number will identify what you've got (along with getting some pictures posted).
shidlerju
No Title
shidlerju
No Title
southkogs
HOLY MOE !! that's like a 60s vintage electric shift Stringer. Did you happen to find that tag on the engine inside?
Not sure about the hole. I've gotta' look a little to see if I can find anything.
southkogs
Well ... ya' gotcha' a Franken-motor. Looks like you do have the '84 3.0, but it's mated to a 60s vintage electric shift. Not sure on that hole though.
shidlerju
Well so.ethung quick this time, will any our drive (like a cobra) hook up to the engine, with little to no mod, or am I looking at this only fits that situation....found several out drives on craigslist, jus don't wanna a get ahead and purchase away and be up creek!!!!!
Ayuh,.... Welcome Aboard,.... Nothin' will fit, other than what's there,....
shidlerju
Another question.... I've seen a picture on Google of a water hose hooked into the side of the drive. I assume this is how I would test out of water since I have no where to put the muffs on. Any thoughts to help my concern? Thanks for your help!
southkogs
You can find those inlet pivot caps online (eBay) ... Your other option is to install a flush kit on the water supply line going into the thermostat. Besides those two options, a Stringer has to be fully immersed in water to operate.
shidlerju
I saw that the other day, being fully submerged, after a Google inquiry brought me back to this site, thanks for the reply!!!!!
Is there a water impeller (circulator) in the drive??
