Motor Not Firing
russellb111
I changed the outdrive, after changing outdrive the boat would not start. The motor is not firing. Does changing the outdrive have anything to do with the engine not firing? The motor is a 1992 MerCrusier with thunderbolt IV electrical, (a 5.7 liter I think)but it is a 350. Any help with this would be greatly appericated.
barroomhero
Re: Motor Not Firing
Removing the drive should have nothing to do with the motor not starting. Does it crank over? What have you checked. Battery condition, loose terminals, is the Emergency Safety switch installed?
Haut Medoc
Welcome to iboats :) Do you have a kill switch safety lanyard? :) There is no relationship between removing the drive and a 'no spark' condition. Answer Bars questions (and mine). Then go to the 'search' section and look for a post by Don S. about trouble shooting ignition systems. I think it is under 'starter is dead'. Maybe someone can hook you up with the link.....JK
rbezdon
you know, pulling the drive on a Merc requires the shift be in gear. Maybe it was never returned to neutral.
Don S
The drive may be binding the cable from the drive if it was installed improperly. Then the shift interrupt switch (If an Alpha drive) would be held to the engaged position which would kill the ignition.<br />If you have an Alpha drive, here is a link to the online manual.<br />Just move your cursor over the cover and index pages to find the links to the other sections.<br /><br /> http://www.boatfix.com/merc/Servmanl/14/14cover.pdf
Haut Medoc
So Don, you're saying that the 'fork' on the shift slide is not engaged to the 'wheel' on the shift lever? Correct? You don't miss anything ...... :D ......JK
russellb111
the motor will turn over fine it just isnt firing to the spark plugs
deputydawg
Check all of the connections. Maybe you accidentally bumped something loose while working of things. Check at the selenoid, the coil, and even so far as the ignition switch.
Haut Medoc
I would definately look at the shift interrupt switch. (what Don S. said)....JK
