I've scanned all the postings but I didn't see one that described my problem. My Mercruiser will idle for approximately 20 seconds and quit (it was running 100% okay prior to this problem). It will restart after a few seconds of cranking and run for another 20 seconds. I pulled the top off the carb and see only a fraction of an inch of fuel in the bowl (not good, I know). The float and needle appear to be functioning properly. The electric fuel pump pumps but I have no way of checking pressure. The fuel filter isn't restricted (I'll replace it since I have it out). The factory manual suggests running the engine from a remote tank which I'm going to try next. It also mentions the anti-siphon valve which I'll also check.<br />I'm thinking that there is an intermittent restriction blocking the fuel flow. Am I on the right track? Is there anything else I should be looking at? Any suggestions will be appreciated.<br />1992 Bayliner Trophy<br />4.3L Mercruiser Alpha One<br />Electric fuel pump
