Any recommendations to replace worn-out Mercruiser controls?
fishnfiend
Have an '86 Searay with 140 Mercruiser. Controls are about shot.<br /><br />I actually prefer a two-lever system with neutral safety switch, or at least a single lever with a throttle warm up control. This is a side mount, although I'm redoing the interior this winter and suppose I could build a console for a top mount if necessary.<br /><br />Has anyone made changes from the stock Mercruiser to anything better (either newer Mercruiser, or an aftermarket?)<br /><br />Thanks for any information.
Ralph 123
Re: Any recommendations to replace worn-out Mercruiser controls?
I changed to Morse. Worked well.
jaybirdtx
Teleflex/Morse are the most common after market and are the preferred replacement. Sierra is my supplier for these.
rodbolt
me I prefer the factory one. it fits correctly every time. duel lever controls have torn up mor gearbox's than I care to count. its usuaally due to something goes wrong and it wont idle correctly so they jack up the rpm with one lever and slaam shift with the other. universal fit usually means it universally fits nothing well.<br /> I dont think brunswick has made a single lever box without a throttle only position in 30 years.
fishnfiend
Rodbolt, the more I learned about the double lever, the scarier it got. I do like the warmup lever on my Evinrude box, but agree that single lever is the only way to go, especially if anyone but me is ever to drive the boat (as in 15 year old son).<br /><br />Thanks for info.
Ralph 123
The Morse (teleflex) shifters have a "throttle only" button that allows you to operate the throttle up w/o being in gear. You move it back to neutral to put it back in dual mode (so you can't slam it in gear no matter what you do)
