Kudos to GLM!
KaGee
A couple of you know that I recently had a bad, newly installed, water pump impeller. The dadgum brass hub spun free of the rubber. I got a RMA from GLM, sent back the impeller (originally bought the complete kit) with the proper paperwork filled out.<br /><br />Well last week, a box shows up with a COMPLETE water pump kit! WooHoo! :) But the real big deal is... I just got a check for $195.00 reembursement for my time and trouble. (3 hours labor @ $65.00/HR) :D :D <br /><br />Plenty gets said on this board when somebody does bad. I wanted to make everyone aware what this company did, and I never complained to them once!
Lou C
Re: Kudos to GLM!
That's good to hear. They do make a LOT of parts for both Cobras and stringers.
tie_one_on
Re: Kudos to GLM!
Hey KaGee, was that $195 by your asking or did they figure it out and send it to you?
KaGee
Re: Kudos to GLM!
Originally posted by tie_one_on:<br /> Hey KaGee, was that $195 by your asking or did they figure it out and send it to you?
Nope, I never asked for anything other than another impeller.
bomar76
Re: Kudos to GLM!
Man, that's a straight up company!
crazy charlie
Re: Kudos to GLM!
Was the impeller one of those new "run dry" impellers which are not supposed to sustain damage if run dry for a bit??? I tried one once and it did what yours did on the first crank of the motor and it wasnt dry.Charlie
KaGee
Re: Kudos to GLM!
Originally posted by crazy charlie:<br /> Was the impeller one of those new "run dry" impellers which are not supposed to sustain damage if run dry for a bit??? I tried one once and it did what yours did on the first crank of the motor and it wasnt dry.Charlie
No it was not. Worked fine for a couple of runs. On Labor day we got about 300 yards from the ramp, never above "no-wake" speed and the temp shot up to 200*+. I thought maybe I sucked up something. Got home, put the muffs on and zero water from the drive.
Boomyal
Re: Kudos to GLM!
Great news KG. How did you buy the kit originally? Direct from them or from a retailer? <br /><br />You do have an 800 Mechanical, do you not?
KaGee
Re: Kudos to GLM!
Ya, Got an 800 Mech.<br /><br />Bought it through Ebasicpower.com.
tie_one_on
Re: Kudos to GLM!
Unbelievable KaGee. Bet I KNOW where you'll buy your next part(s).
Boomyal
Re: Kudos to GLM!
Originally posted by KaGee:<br /> Ya, Got an 800 Mech.
Then hows come you don't have the leetle fitting on the pivot cap to supply water to your unit when it is out de vasser???
KaGee
Re: Kudos to GLM!
Originally posted by Boomyal:<br /> Then hows come you don't have the leetle fitting on the pivot cap to supply water to your unit when it is out de vasser???
I have not seen one yet on Ebay. The one's I've seen to date are for the older units. That was an accessory add on you know.
KaGee
Re: Kudos to GLM!
Originally posted by tie_one_on:<br /> Unbelievable KaGee. Bet I KNOW where you'll buy your next part(s).
Trust me, I have spent a few coin with them before this. They are an excellent source for Stringer parts.
Boomyal
Re: Kudos to GLM!
The best I understand KaGee, they are all interchangeable from electric thru mechanical. I have an early one that does not have a complete plate for the end cap with the hose fitting on it, but I could put on the later one and it would fit and work.<br /><br />I have the electric era intermediate with the 800 hydro-mech unit scabbed on.
THE BEEF
Re: Kudos to GLM!
Nice to see something good about a supplier.<br />I'll be going here for my stringer parts!<br />Hey Captain, ever go to the docks for a beer?<br />Gumbo's? :D <br />Beef
