Re: Ignition/plugs
I don't agree that you will see no benefit if you do not open up the plug gap.<br /><br />Yes, it takes the same amount of voltage (about 10 kilovolts at idle) to fire the plug regardless of how much voltage is available. But actually all the energy available in the coil is used on each firing event. Any energy not used in the initiation of the spark will increase the duration of the spark (burn time), which helps combustion. So there is a benefit, even without regapping plugs. <br /><br />I also do not agree that varible dwell affects timing. Variable dwell starts the coil charge time sooner, but the removal of ground to initate the spark occurs at the same time as a fixed dwell unit would.<br /><br />Dave
