Alpha 1 Shifting Problems
555plumber
Hello Everyone, I was wondering if you could give me some advice on some problems with my 1990 Bayliner Capri 180 ,its powered by a Mercruiser 3.0 with an Alpha 1 outdrive.The last time I took it out it ran great for about a half hour but when I stopped for a little while I had a hard time getting into forward but I finally got it into gear. The boat ran fine for a little while longer but when I stopped again I couldnt get it back into forward or reverse.I checked the shift interuptor switch and it seems to work fine.I also noticed after I got it back home that I can spin the Prop both ways by hand if the drive is down but if I raise the Drive up to the trailering position , I can only spin the prop clockwise and when I try to Turn the prop counterclockwise it locks up. also when it turns by hand clockwise I hear a clicking sound. Any info would be greatly appreciated....thanks
rodbolt
Re: Alpha 1 Shifting Problems
sounds like a problem in the lower shift cable someplace if drive angle changes gear engagement.<br /> repost this on the mercruiser forum and you will get a lot more replies. do you have the factory service manual? have you checked the condition of the gearcase oil and the lower magnet for metal?
555plumber
Thanks for the reply rodbolt.I have the clymer manual for the engine and sterndrive.I changed the gearoil 2 weeks before i started having shifting problems and there were metal chips on the magnetic drain plug, but in the manual it says that a minimal amount is from normal wear and tear.....I had very little...somebody mentioned to me that it could be the motor coupler but I didnt smell any "burnt clutch" smell or rubber burning.I dont know if this will help solve the problem, but the guy I bought the boat off told me that he stored the boat for 3 years with the outdrive in the full up position...could that have anything to do with it?
rodbolt
beats me.<br /> its possible. have you inspected anything? and describe going into gear. did the shifter move ok? a spun coupler hub will normally allow for idle sppeds only. spun coupler splines will allow no speeds and cause an overheat, a broken upper drive shaft will allow no fwd motion and no water pumping.
555plumber
It shifted smooth the first time I shifted and the second time it reved up a little and "slipped" into gear with a "clunk" but it ran smooth after that with no strange noises from the powertrain.But the third time I tried, it just reved up and wouldnt go into gear.......It wouldnt go into forward or reverse,I had to get towed back to the ramp. Tomorrow I will check the gearoil again to see if any more chips are present.Could a spun propeller hub be the culprit?.....I have never hit anything, but when i bought the boat there were some major dings in the prop...some are even "curled" over...Thanks again for the quick reply
Don S
Very fine gringing compound like stuff on the magnet is normal, Chips are not normal at all. That is something coming apart.<br />I would suggest you get the drive inspected by a qualified Merc mechanic, before you loose the compelete drive. Bent over blades indicates impact. Could be the upper drive gear trying to turn in to a smooth gear or even the lower pinion. What ever, chips are NOT normal.
555plumber
Sorry about that, what i really meant was really fine grit from wear and tear.....Thanks for the advice Don
You Might Possibly have Other Issues as well,......<br /><br />But,... You Definitely Need a Lower Shift Cable...........
