Which gasket sealer to use to install water pump
harrisg
I got my circulating pump (antifreeze) back from rebuild for an AQ125A Volvo Penta. The final cost was $78.00. NAPA sent it to one of their vendors and it cost about 1/3 of a new one. Only took a couple of days. I'll run it in a tank after I install it but it'll be next spring before I can really put it to a test. <br /><br />My question is really pretty basic. Since I'm not much of a mechanic I'd like to find out the difference between Permatex red and blue, which one I should use for this application or is there another gasket sealer I should use.
Weirdwalt
Re: Which gasket sealer to use to install water pump
Red is for high heat. Blue is fine for the water pump
KaGee
The "ULTRA-BLACK" is what I keep around. It's good for most applications. <br /><br />Keep in mind that Silicone seals only as good as you have prep'd the surface. You also need to let it cure (usually overnight) before operating.
