cw_racefan
Thread starter- Joined
- Oct 19, 2005
- 20
Can anyone recommend a pump for quart gear lube containers that will actually fit the drain plug on a duo-prop (the drain hole behind the props)? I have 2, one is too big diameter to fit back into the hole, the other is smaller, but the threads are too short, since the threads in the hole are recessed. <br /><br />What do other people use? My dealer doesn't carry anything, and said that they had to fab. their own. VP sure makes this difficult, first making you pull the props, then finding something to fit the drain plug hole.<br /><br />Thanks!<br />Craig
