Mercruiser 2.5 3.0 carborator?
itareme0
I have a 74 3.0 mercruser that has a bad carborator. We have a carb. off of a 72 2.5 mercruiser but it will not fit the 3.0. All the ones I can find says for a 2.5 or 3.0. I do know that the intake on the 2.5 has been replaced and the carb mounting bolt pattern is larger than the 3.0. Could this intake be off some other drive other than mercruser and if it is is there a way to tell whitch is whitch? :confused:
Laddies
Banned
Re: Mercruiser 2.5 3.0 carborator?
It sounds like your 3 L. has a newer style manifold for the Merc. Carb and newer Rochesters
woosterken
I have a 1974 mercruiser 120hp also the little tag on the carb.says GM rochester 2jet part num.<br />1351-5202a1<br />ken
Laddies
Banned
Took a little time and reread this thread, first there were no 3 liters in 74 the were 140s till about 83 if your carb was the original the tag number should be 1351-4293A1 or 1351-5203A1 they both cross to 1347-818620-1. A 1972 120 carb is numbered 1351-4263A3 and was changed to 1351-5202A1 in 74, neither of the 120 carb. are interchangeable to your engine
woosterken
Laddies,thanks for the info,could you tell me where you found all that info?I have a 1974 MFG gypsy with a 120hp merc.and I am trying to make a owners manual (if you will)and would like to document all the parts and pieces are original.<br />ken (kralyon@sssnet.com)
Laddies
Banned
Seirra parts book rebuilt carb section
