FreeBeeTony
- Joined
- May 15, 2002
- 3,995
Is it OK to paint the outdrive now and have it sit until spring? Or does the anti-fouling paint loose its effectiveness if not put in the water?
Yep..the one and ONLY way. Period. Not cheap, but works. Good prep first of courseOriginally posted by Lou C:<br /> Interlux sells Trilux for alu but you are supposed to use the Primocron base coat first.
Ya might try Transducer paint too, a little cheaper, might work on Aluminum OK. I sprayed my SS trim tabs, with no adverse problemsOriginally posted by Lou C:<br /> unless you stillh have a stash of Petitt's Alumaspray (tin based) somewhere----
