Painting Outdrive
FreeBeeTony
Is it OK to paint the outdrive now and have it sit until spring? Or does the anti-fouling paint loose its effectiveness if not put in the water?
trog100
Re: Painting Outdrive
some of it does depends what sort u are useing.. are u painting yours for cosmetic reasons or practical ones..??<br /><br />trog
FreeBeeTony
Not cosmetic.....I keep the boat in the water (salt). Paint is to prevent growth.
Don S
If you are painting it with anti-fouling, it depends on the brand you're using. Check the lable on the can, it should tell you.
trog100
praps i ought to put some on mine... he he..<br /><br />
<br /><br />trog
Lou C
trog looks like you don't run that thing much over idle, or very often!<br />Here we get barnicles up in the pivot housing even with antifouling paint.
Haut Medoc
Trog, she's a beauty!....I wouldn't change a thing! :) .....JK
trog100
the stuff does come off easy with brush.. and yep a good blast at WOT does take lot of it off.. its a freshwater river boat.. 6 mph speed limit.. i have to make sure no one is about before it gets a blast.. he he..<br /><br />i do the bottom of the boat once year that stays clean.. the drive takes only about two weeks moored up to get like that.. again once year i give it a good scrub down and retouch any bits on the drive with damaged paintwork.. the crud dosnt seem to do much harm and cos the boat stays in the water u dont see it very often..<br /><br />the antifoul bottom paint i use tends to suggest u should keep it well away from the drive.. not sure how valid this is thow.. <br /><br />trog
crazy charlie
There are very few AF paints that can be used on alum. outdrives.None that I know of will be effective if you paint it now and put the boat in the water until the spring.
Lou C
Interlux sells Trilux for alu but you are supposed to use the Primocron base coat first. The issue is they stopped making the tin based paints which worked well for alu. Conventional bottom paints have copper which will cause corrosion (galvinism) of alu. The Trilux does have copper in it but using the Primocron insulates the alu from the copper, and the copper used is different than that used in regular bottom paint.
KRS
Banned
Wow Trog, that looks terrible. That's some murky water around there.<br /><br />We have a few lakes in Arizona, but they look cleaner than that.<br /><br />6mph limit.... arrrgggghhhhhh! I couldn't handle that.
markvictor
Be very careful when using antifouling paint on your drive...Do Not use copper based bottom paint...it will turn your drive to mush...also, if your hull is painted with antifouling paint, you must leave an inch and a half gap between your bottom paint and your drive...per mercruiser...this prevents any electrical continuity between your drive and the bottom paint...which turns your aluminum drive into one big anode protecting the bottom paint...in other words, your drive will dissolve...
flashback
Hey Trog, leave it the way it is, that way no one will steal it.. :D :D
trog100
they might steal the nice clean 5hp merc four stroke kicker u can just see the top of fastened next to it thow.. he he he..<br /><br />trog
flashback
yep they might :D My 7.5 honda kicker used to look pretty good till I did a real sloppy paint job on it, It runs like a champ but looks like hell- :D
Scaaty
Originally posted by Lou C:<br /> Interlux sells Trilux for alu but you are supposed to use the Primocron base coat first.
Yep..the one and ONLY way. Period. Not cheap, but works. Good prep first of course
Lou C
unless you stillh have a stash of Petitt's Alumaspray (tin based) somewhere----
Scaaty
Originally posted by Lou C:<br /> unless you stillh have a stash of Petitt's Alumaspray (tin based) somewhere----
Ya might try Transducer paint too, a little cheaper, might work on Aluminum OK. I sprayed my SS trim tabs, with no adverse problems
