Re: more from tashasdaddy
am i correct in thinking i am going to have to pull the engine,
It's no good the way it is, and only pulling the heads is a waste of time. You also need to see what the main and rod bearings look like. And you can't do that with the engine in the boat.<br /><br />
do a rebuild or by a reman.
That depends on what the block, crank, heads, cam, etc. looks like, and a lot to do with your mechanical skills. Rebuilding an engine is not just following steps from a book, but knowing what to look for both in the old parts, and fitting new.<br /><br />
if this is the case it won't hurt me to wait for a couple of months.
Water and steel creates rust. The longer rust exists the worse it is. Your engine may be rebuildable now, but not in a couple of months, or days for that matter.<br /><br />
i think i know when to bite the bullet.
Not really, in all the time it has taken you to "fix" the manifolds on an engine that ran "Fine", it's now locked up...... You might want to restate that as "i think i know when to open my wallet."<br /><br />I have this funny feeling you are starting to understand that being a boat mechanic is not as cut and dry and easy as most boat owners seems to think it is.
