Hey everyone
<br /><br />1985 Mercruiser. Chevy 350 V8 engine. 260hp.<br />I was trying to remove the thermostat housing assembly (the whole thing) and one of the bolts broke (the bolt on the port side of the motor if facing into the engine compartment, its the right bolt). I was able to remove the other bolt, and the bolt didnt come out because it was frozen somewhere inside of the thermostat housing assemble. Its not frozen where the bolt goes into the intake manifold because I can remove the other bolt and Im able to move the housing from side to side. I put a lot of pressure on the bolt before it broke, so I dont have much confidence that I can get this bolt out.<br /><br />1st question: If I remove the carburetor, will I have enough space to be able to turn the entire housing all the way around and just unscrew the entire housing or will the housing bump into the manifold?<br /><br />Any suggestions as to what to do?
