Re: OMC King Cobra Outdrive gear ratios
Pat, <br /><br />I looked in my OMC service manual, and found the following. (mine is a 1987 7.5L King)<br /><br />I have the 754BPFTC, upper gear ratio is 21:17, lower gear ratio, 17:30 <br /><br />you multiply the fractions 21/17 x 17/30 = 0.7 (similar to calculating the final ratio for a transmission/OD and rear end in a car or truck)<br /><br />0.7 means "1 rev of the U-joint shaft results in 0.7 revolutions of the propeller shaft" (taken directly from the OMC manual)<br /><br /><br />Overall ratios for <br /><br />2.3L ... 2.00:1<br />3.0L ... 1.71:1<br />5.0L ... 1.50:1<br />5.7L ... 1.41:1<br />7.5L ... 1.43:1<br /><br />According to the OMC manual, for the 7.5L drive, "1.43 revolutions of the U-joint shaft results in 1 revolution of the propeller shaft". <br /><br />So for the 7.5L, <br /><br />"Total Ratio" is 0.7 and similarly the "Overall ratio is 1.41"<br />(The 2 mean the same thing)<br /><br /><br />So this isn't "new" math.....evidently the person wrote it down or read it wrong. It's 1.41:1 ......This makes it a vertical drive from a 5.7L application. <br /><br /><br />Hope this helps!<br /><br /><br />Regards, <br /><br />Rick
