Manual?
davehirt
Just purchased an '84 Stingray runabout with a Mercruiser model MCM 140 engine. Where can I find a manual for the engine? One for the boat would be nice too. First boat, would like to be prepared....<br /><br />Thanks, <br /><br />Dave
Re: Manual?
If your any kinda Mechanic,........<br />Your going to find it's Worth the extra money for a Factory Manual for the engine,+ drive........<br /><br />If you're a DIYer,........<br />You'll probably be able to get by with an Aftermarket Manual,.......<br /><br />For the Boat,....... You'll find they're pretty Genaric.......<br />All the boat builders buy from the same suppliers,...... Taco rails,... Taylormade windows,....etc.....<br /><br />If you're Just Looking to Learn about the Ins,+ Outs of your boat,..............<br /><br />You've Found the Place,...........<br />The Knowledge here in the iboats forums, both Live,+ the Archives,...... Can't be Bought,....... Anywhere.........<br /><br />Welcome Aboard......... :)
davehirt
Re: Manual?
Thanks Bondo, I guess I'm kindof between the mechanic and the DIY. Aftermarket manuals -- is that like Seloc? And is the best place to get a Factory manual would be directly from Mercruiser? Or is there a better option? Thank you!<br />Dave
Re: Manual?
Ayuh,...... There's Seloc,.... Clymers,..... Maybe Haynes......<br /><br />Hopefully Don will see this,+ Post the Link he has for the Factory Manuals,........<br />Or,...<br />ebay is a Great Resource for Factory Books........<br /> This just Might get you Started..............
davehirt
Re: Manual?
Thank you for the link Bondo!!<br />This will definitely get me started in a good way!!!<br /><br />Dave
Re: Manual?
IF you can figure out HOW to navigate thru the Acrobat,....<br />I Think you Should be able to access the Manual on Your Drive,.......<br />I Know the Alpha 1s Are covered........
Don S
Re: Manual?
You can order the manuals directly from Mercruiser, but you need an engine serial number to do that. You actually need service manual #3 for your engine, the link Bondo gave you is for the 90-97 vintage engines.<br />Here is one possibility for purchasing the manual online, for the same price, you can go to your local Mercruiser dealer and make friends with them.<br /> http://www.stemtostern.com/catalog/displayproductdetails.asp?DepartmentInventoryRefID=444640 <br />Ebay is another option.<br />The manual for your drive is #6, here is a link to the Merc online manual.<br /> http://www.boatfix.com/merc/Servmanl/6/6covr3.pdf <br /><br />Personally, I would avoid the Clymers manuals at all costs, to many mistakes to even make it usable. Seloc is only slightly better.
Re: Manual?
Don,......<br /><br />Do you ever venture over to BoatingABC,..???.....<br /><br />If you Ever Do,..........<br /><br />Don't Say That,............ Unless you're Looking to get a Good Beating...........
AaronG
Re: Manual?
I've used stem to stern. They are very good. No tax or shipping (if you spend over $100). <br /><br />I bought the factory manual for my drive, and I'll be buying the engine manual before the season. There is no substitute for the real manual. Don't waste your time with an aftermarket one.
davehirt
Re: Manual?
Thank you Don and Bondo!! So, I need the #3 and #6 service manuals to get me started right. Will hunt ebay first, don't mind the cd-rom version. Just got the boat, and want to do all the maintainance items, etc first before even putting it in the water. Not sure what has been or has not been done in the past..... <br />Dave
