Stainless steel or Aluminium prop?
bijou22
Hi everyone, I was wondering if there were any advantages of replacing my ali prop with a new stainless one, apart from the fact that the stainless one will not corrode. My boat is kept in saltwater throughout the year.
WillyBWright
Re: Stainless steel or Aluminium prop?
Stainless will exacerbate motor component corrosion (I always wanted to use that word ;) ). At least the bare metal ones will. They make great grounding electrodes in the water and can multiply an existing corrosion problem by many times. You can clear-cloat it, but nothing sticks to polished stainless. They perform better and withstand hitting obstructions better, which can transmit the shock to the gears which may fail instead. They add strain to the drive gears and shifting mechanism with their added mass. They reduce strain on the powerhead by slicing thru the water with thinner blades.<br /><br />Might you consider a composite prop? They have fairly thin blades that slice thru the water very nicely, come in 4-blade configurations, the plastic completely eliminates the prop as a corrosion component, you can destroy them on a rock pile without damaging grearcase internals. I had one on a 15' tri-hull with a 60 triple Evinrude and I loved it. The blades flex which gives you sort of a gear-reduction on acceleration, then straighten out at speed. But you can't repair them. :( (I've never seen one on a sterndrive. Don't know if they'll take it.)
crazy charlie
If performance is a major issue then SS is the only way to go_Otherwise ,electrolysis and galvanic corrosion have the potential of greatly accelerating with the SS prop and alum. drive.Cost is another major factor.
HT32BSX115
Also, if you are making serious HP your only choice is stainless steel. Someone can help me here but the upper limit for aluminum is about 280-300hp?<br /><br />We tried an otherwise identical 19p Aluminum on the FourWinns 211 liberator(340hp) and it was a dog out of the hole and would barely plane. With the 19p SS it not only "shot" out of the hole but ran right up to about 60mph! I very fortunate to avoid exacerbation by mooring my boat in the garage!<br /><br />Cheers, <br /><br /><br />Rick
bijou22
Thanks for the advice, it seems there are plus and minus points for changing to s/steel. What about a conversion to duo-prop, how hard is it?
mkast
It's not hard... it's expensive!
cmyers_uk
What engine are you running / boat what are you trying to achieve by changing to SS / Duo-prop.<br /><br />If you switch to duo-prop you still have got to decide on Alu / SS.<br /><br />If you do switch to duo props remember to grease the shaft regularly there are many posts where they need to be cut off.
cmyers_uk
bijou22
boat is a wellcraft 21sl with volvo penta 4.3 v6 with cobra sx leg 1996. Its not something i am going to do now just wanted some background info.
ewenm
i was told that VP won't warrant aluminium props for speeds over 40mph i had to go to ss and yes they are expensive (duo props) and i havent noticed any adverse corrosion in my case, still need to check anodes at regular intervals but no change in frequency of replacement<br /><br />Ewen
