At high speed temperature gage goes to red<br />slow down to half speed and temperature goes to normal. idle is also normal<br /> This raw water cooled Merc.
Is this a raw water cooling or closed cooling system. Merc, Volvo, or OMC?<br /><br />Most likely,,,water pump impeller failure, t-stat failure, or restriction in cooling system
The raw water impeller is the first thing you look at on ANY overheat problem on any make.<br />Usually they are expected to last forever, but in reallity should be replaced every couple of years.
