Is Starter my problem
tony22770
Engine cranks strong - wants to run - is it possible starter will not disengage from flywheel not permitting the engine to run?<br />When remote starter is connected to starter solenoid it will crank for a couple of times then not work. Connect remote to slave solenoid and cranks fine.<br /><br />1989 4 cyl. 3.0 mercruiser - mercarb electric choke - points distributer - Morse/Teleflex controls.
vipzach
Re: Is Starter my problem
Anything is possible! You should be able to hear the starter still spinning if the engine is running. I would be looking at the timing, spark and fuel!
No......<br /><br />The engine will start,+ Run,.... Even if the starter Doesn't Disengage........
tony22770
Thanks Bondo - tonight I will have someone turn ignition to start & check coil for spark.<br />I have covered most items from changing gasoline in tank to carb to distributer etc. any other thoughts -
remote will crank a couple of times and then not work. check the wiring and connections. sound like it's getting hot and causing an open circuit.
Mischief Managed
When you say it "cranks strong and wants to run" do you mean it fires while cranking and then dies as soon as you release the key? If so, your kill switch is likely in the "off" position.
tony22770
Cranks strong (and as long) as I hold key to start position - when I release key to run position it just stops. I can't really say it's firing at that time.<br />Thats why I'm looking at no spark at the coil using key switch to start tonight. Plenty of coil spark when using start switch at starter or solenoid. <br />Am I going in the right path?
Mischief Managed
That is the classic symptom of the kill switch being activated (off). Does it have a kill switch on the shifter/throttle? If so, it need to be turned back on.
tony22770
I have a kill switch on the dash (1989 Maxum) I can't figure how it works, there is a lanyard line attached to a clip device that slips over the neck of the switch. No visible spring activated feature that I can see when removing the clip unless it's just frozen in "on" position. <br />Testing connections behind kill switch I find current to one pole and not the other, when you say "off" I have a feeling I should get current at both terminals then the switch is "on"
Mischief Managed
Originally posted by tony33770:<br /> I have a kill switch on the dash (1989 Maxum) I can't figure how it works, there is a lanyard line attached to a clip device that slips over the neck of the switch. No visible spring activated feature that I can see when removing the clip unless it's just frozen in "on" position. <br />Testing connections behind kill switch I find current to one pole and not the other, when you say "off" I have a feeling I should get current at both terminals then the switch is "on"
Yup; well, voltage really, but anyway... Jump a wire accross the two poles of the switch to take it out of the circuit and the boat will likely run. Perhaps the switch is bad. Mine is basically a toggle switch that the lanyard will turn off when it's pulled out.
tony22770
Mischief Managed<br />I owe you one - trying tonight when I get home.<br />Thanks for your interest.
Mischief Managed
Originally posted by tony33770:<br /> Mischief Managed<br />I owe you one - trying tonight when I get home.<br />Thanks for your interest.
My pleasure.<br /><br />First time out with my 2nd boat (the first boat I ever owned with a kill switch), I hit a wave in a very busy channel and the engine died. It exhibited the same exact symptoms as yours and I was freaking out as traffic was passing me left and right and I was just drifting. A good Samaritan gave me a tow and about 5 minutes into the tow, I thought to check the kill switch. Doh! I had hit it with my knee and it was between on and off with the lanyard still in place. Fired right up when I turned the switch to on. I'll never forget that.
tony22770
Mischief Managed<br />You wrote:<br />"Yup; well, voltage really, but anyway... Jump a wire accross the two poles of the switch to take it out of the circuit and the boat will likely run. Perhaps the switch is bad. Mine is basically a toggle switch that the lanyard will turn off when it's pulled out."<br /><br />Guess what "IT RUNS"<br />Can't thank you enough<br />Bad switch - jumping the switch can't say I will ever use the kill switch what with going forward and aft when boating.<br />Thank You
