swaycleveland
Thread starter- Joined
- Mar 28, 2010
- 91
So, i finally pulled the trigger on a new prop. the boat is a 85 4 winns 21ft 3.8 omc stringer with a 14.25x 19 ss 3 blade.. so i pulled the trigger on the 4 blade solas. I was hedging my bets on the 14.5x15 4blade for a couple of reasons. My reasons, addition of kicker motor ( 93 9.9 evinrude mounted on a omc 15hp bracket mounted on port side.) Next reason is i run with a convertible top and it adds some drag and dropped me down where with a full load i could just barely make it up to WOT rating. Next reason for the 15 pitch was going from the SS 3 blade to the 4 blade alum i was trying to compensate for that. All that being said, NOTHING CHANGES UNLESS SOMETHING CHANGES.
The only thing ive changed is the prop everything else is the same. However now she is pulling to the right i have adjusted the steering tab on the outdrive and does not help. The only adjustment i can make is my bennett trim tabs. I can adjust those to make her run straight, but that is not fixing the problem.
So.... While the 4 blade pulls nicely and got me back to the right RPMS. I do notice a bit of prop slip. I know running the tabs so out of wack to compensate is costing me preformance, plus the constant right turn is pissing me off.
Anyone think i should buy a 3 blade 17 or 4 blade 17? heck at this point ill take any ideas i can get
thank you iun advance
