Donald Terrell
Thread starter- Joined
- Jul 17, 2004
- 69
If your are reading this Thanks. I found my antisiphon valve, it was going into a 90 degree fitting on top of the tank. I removed it and inspected it, looks super clean, blew into it from the tank end and it took a moderate amount of pressure to open, seemed okay and wouldn't allow gas to flow backwards at all. I removed the 90 deg fitting wondering if the pickup tube would be attached, it wasn't. I had done a fuel volume test on the muffs, in the driveway, passed good. I put the antisiphone valve and fitting back on, with sealant of course and closed the fuel tank as being a problem. My boat used to run really good, and it just over a few outings began to perform poorly. I done a compression test, passed with flying colors and I am going to do a proper and complete tune up when I figure out exactly what I need. I have also been reading the post about the elusive OMC shift cable adj. When I first purchased my boat, really the second owner, great people, the boat would always make one thud like sound as you started in forward. As long as I throttled up kinda quickly, I would hear no other noises. The prior owners said it had always done that.I asked a marina which was servicing the boat, that's when I learned about the replacement shift cable, which I had. The service tech told me he could tighten it up a little and for a season it didn't make the noisebut it did eventually come back. I plan to remove the drive, build the holder with the help of some great post, buy the kit with gaskets,gimball bearing and belows. I was just outside trying to decide where, my wife will kill me when she comes home and the boat is on the car port. While I was checking the antisiphon, I measured the distance of the top of the lower shift cable 7-9/16, that one. Mine was more like 7-3/4 which leads me finally to my second and last question. Is this a result of the marina adjusting the cable tighter for wear of the clutch dog and if I don't replace the gears, which I hadn't planned on will I have to adjust for this when I put it all back together or just set everything like the 7-9/16, angle of bellcrank etc. The shifting has become very difficult, not on the remote end though. Sorry for the long shpill! Apreciate any feedback. Thanks Donwon
