ESA Installation / Wiring
jth737
1984 OMC 800 Series drive - 1997 Chev.5.7 liter 260 Hp w/ electronic ignition - neither of which were original equipment in my 20' Grady White (1980).<br /><br />I was the the first operator of this boat after the engine outdrive change from the originally supplied 4 cyl. engine. Shifting into neutral from either forward or reverse was impossible and after some internet research it became apparent that this set-up needed the shift interrupt / ESA <br />installation. I've found and purchased the correct shift converter box and the ESA module however I've not been able to find any information on the wiring connections. I understand that with the new ESA modules it's no longer necessary to use the second switch on the shift converter box. Can someone steer me in the right direction here !<br /><br />Thanks<br /><br />Jon<br />jth737@verizon.net
KaGee
Re: ESA Installation / Wiring
That's the trouble with half breed modifications.<br />What type of ignition? The ESA's were used primarily with traditional ingnitions.
jth737
Mallory electronic ignition and the ESA module ( CDI/Rapair) is the Petronix version.
KaGee
Does your shift adapter have the interrupt, the overstroke switches and plug on it?
jth737
Yes. Both switches are wired into a common 4 pin female connector.
KaGee
Try these...<br /><br />Don't know how it will work for you, but it's all I've got. <br /><br />
<br /><br /><br />
jth737
Keith,<br /><br />Just what I was looking for ! Thanks so much for the help. I'll let you know how it goes !<br /><br />Jon
