v8 mercruiser removal replacement
hudman
Tryint to remove-replace 5.7 l, It looks to me like it would be a lot easeir to premount the y pipe to the transom plate, then drop motor in--is this common practice? thanks for putting up with me guys<br />hud
Bt Doctur
Re: v8 mercruiser removal replacement
the Y pipe is already mounted to the transon plate.need to pull the drive, remove exaust clamps,rear mounting bolts, front mounts, cables,wiring ,install lift chain and pull up and out.once reinstalled ,check alignment and install drive
Ayuh,....... That's How it's Done.......... ;)
hudman
Engine out 11 am , memphis time, total time for removal 1 hr 20 min<br />thanks guys<br />hudman
What Took you So Long.............. :D <br /><br />Airtools would have Saved a Hour........... :D
hudman
we have air powered tools available, but not air powered brains!!
lilmandavis
yeah ive got it down to a science probably could do it without even takin the drive out!!! small blocks big blocks .. i take about 40 minswith wrenches and wratchets!! :)
