Re: CRANE HI-6 M QUESTION
Well, you were warned........<br /><br />IMO, I just dont understand why you (anybody) would think that a state of the art ignition system designed and installed by one of the worlds biggest automotive manufactures (GM) and than modified for marine use by the worlds leading marine engine company (Mercruiser) will benefit by adapting an after market system. I have no issue with the Crane and I agree its possibly the best of its type on the market but its designed to work with serious modifications such as supercharging, in that application its adjustability will work well as the effects of serious modifications are outside the normal scope and range of the factory system. It may also work well when fitted to an older less hi-tech ignition but it will not fix your rich condition, it may cover it up if it works at all!! But its just not the way to fix it. You have a problem and nobody will deny that but to attempt a backyard fix by fitting an aftermarket piggyback ignition to that engine is a recipe for disaster. My trade master always told me that the worst two things the average boater can possess are a curious mind and a bit of mechanical knowledge. You seem to have the money, so get that thing checked out by a pro, the best advise you have received is from Don, ignore it at your peril! Good luck, me thinks your gunna need it.
