Sonic Rodent Repellent While Storing Boat
four winns 214
For winter storage, I keep my deckboat in a metal storage building with a gravel floor at our small farm property 250 miles from our primary residence. I've never had a problem with mice getting into the boat until last year. They got in with a vengeance. Fortunately, the only real damage was to the bimini rolled up in the stored position. A mouse got in between the folds and chewed away and created a small hole. When I look at all the cables and wires on the EFI engine, I thank my lucky stars they didn't get in there!
To combat the little suckers this year, in addition to the Tomcat mice poison bait stations I've always used, I'm considering using the Victor sonic rodent repellents:
http://www.victorpest.com/victor-pestchaser-pro-bm792promo
Am I wasting money trying to use these in a boat?
Chryslerman123
Anything is worth a try in my opinion. I've never had much luck with sonic pest repellers although they seem to have worked on several occasions for me. I would still use the poison but they could just eat the poison and then get into the boat and die or still cause damage. I think it might be worth a shot, after all, you don't know if you don't try.
Dixiedawg
I have worked in the pest control industry for about seven years for a very reputable company, and I can tell you for sure that the sonic repellent devices are nothing more than a gimmick and do not work! If your boat is stored in a place where you cannot realistically seal the mice out, which means no gaps 1/4" or greater, and no holes the size of a dime or larger, then your best alternative would be either several tin cat repeater traps, or rodenticide. Just make sure that if you use rodenticide that you put it in rodent bait stations so that it can't be accessed by other critters or kids! Hope this helps!
dozerII
I have an old 2 bay garage that is infested with mice. Two winters ago I stored a boat in there with one of these devices, in the spring we never found a sign of mice anywhere on the boat cover or in the boat.
Tnstratofam
I got a tip a few years ago from a customer who said to buy a bar or two of Irish Spring soap. Shave off some in a paper or plastic cup, and place the cups in a few different locations. Works as a good repellent kind of like mothballs only stronger. I've used it in my old Jeep and in one of our boats stored outside with no rodent or bug activity. I change the cups once around mid winter, but to be honest I don't think it's necessary as they still seem to be working.
WIMUSKY
Cotton balls soaked in peppermint oil. And it smells good too.. I put couple of the sonics in my garage. Still mice sign everywhere.....
gm280
I can't say because I have never had an issue to need them. But I would certainly have to see verifiable facts that they worked. If they could set up a positive scenario with mice going after food and then turn on the sonic circuits and the mice wouldn't go after the food anymore, then I would be a believer. But other then that, I'm not going to buy $90 plus dollars worth of such things on a hunch. JMHO
dlngr
I tried the irish spring once,the mice nibbled on it,on my garage floor-they never got into my car,because it had moth balls under the seats and in the trunk..I use mothballs in my old car,and also this year I am using the peppermint oil on cotton balls.[maybe the mint will disguise the moth ball smell in the spring!]
82rude
Build a couple of canadian camp mouse traps.One or 2 5 gallon pails ,top off ramp leading to top with a wire strung across the top going through a pop or beer can in the middle.Put peanut butter on can and put water and bleach or the likes in the pail.Mouse runs up ramp ,across wire to peanutbutter ,can spins and deposits rodent in water where it drowns.Have caught hundreds if not much more that way up at camp.
WIMUSKY
Nothing like a bucket full of wet dead mice........ :) I check on some cabins, find a few in toilets after eating poison... Flush away.....
gm280
I guess the only thing you have to watch out about poisoning them, is if they eat the poison and then get back outside before dying. Then something else eats the mice. That could kill other animals that are really beneficial to the wildlife. JMHO
82rude
Problem with poison is they can crawl off and die where ever.The bucket trick theres no smell and their all in one place.The camp further down used poison and the dead buggers were everywhere and stunk.
WIMUSKY
They store DECON everywhere too. Smells great if one dies in the wall.... Haven't used DECON in a long while..
CraigBarnard
Can you still get moth balls?
Cant get them in Canada anymore.
Blind Date
I put Bounce dryer sheets all over in my SeaRay. You can also spread moth balls around the perimeter of the boat on the ground.
What he said.... Also keeps spiders away and keeps the boat smelling spring time fresh. Works for keeping mice out of storage units as well
Old Ironmaker
I store shrinkwarapped outdoors. They can get in at the transom. Bounce sheets and Irish Spring. No mice after 8 years of doing this. They just get into the cottage.
