- Joined
- Mar 5, 2006
- 30,804
Yes, if you can find glass stringers.
There are way more issues with an 80's Bayliner than just stringers. I owned one and kept it up in pretty good shape and I am in a dry climate for the most part. It is just built with such low quality that there isn't much you can do to keep it from falling apart. Poor fittings, poor sealing of edges of plywood used. You just take a look at how the seat structures are built and you will shake your head. They don't even use stainless staples for the upholstery so they all rot out!. I can go on.
I would look for a boat with a fiberglass floor. If you keep the boat covered and the bilge dry, you should not have problems with rotten stringers.
